Fuel Mileage
Old Mar 30, 2011 | 02:36 PM
kerley's Avatar
Default Fuel Mileage
What's the average acceptable fuel mileage on a 1998.5 Cummins 4x4 5speed stick. The truck is totally stock and runs well, just loves diesel. What can be done to increase fuel economy?
Old Mar 31, 2011 | 11:59 AM
01_cummins's Avatar
i have an 01 24v HO with 6 speed and i was getin 14 mpg then blew the head gasket and replaced it and i checked my valve lash and there were many that were way way outa accepted spacing i had a couple over 30 thousands off so i evened all of them to corect specs and now i get 22 so maby check ur valve lash, then id start upgrading programers intake exhuast ect... good luck and hope that helps
Old Apr 2, 2011 | 07:14 PM
four_wheel_n's Avatar
I have an '01 24v with an auto tranny, edge juice with attitude, intake and exhaust. I'm gettin 13 on the mileage setting...would the valve lash be something you think I should check into? The truck has 170K, is there anything else I should check out to help the mpg's?
Old Apr 2, 2011 | 08:33 PM
KillStroker's Avatar
It says on your Cummins Maintenance book that you should check your valve lash at 150k so you might want to give it a once over anyways.
Heres a video by DieselMinded on valve adjustment to help you along.
https://www.dieselbombers.com/dodge-...ent-video.html
Last edited by KillStroker; Apr 2, 2011 at 08:33 PM. Reason: Automerged Doublepost
Old Apr 4, 2011 | 03:40 PM
ZX10Aviator's Avatar
I have an auto but get 22 on the highway, 16 around town. Manual should get at least that.
Old Apr 4, 2011 | 03:54 PM
dukeboy_318's Avatar
my truck with 150 hp sticks, and some other stuff is getting around 17to 19 in town/country. Highway I can see about 22 mpg. not bad if for a 450 hp truck wieghing 7800 lbs without me in it
5sp manual, SB DD and 305/70/16s
Old Apr 4, 2011 | 05:18 PM
chadcycle 2500's Avatar
would mileage very with gear ratio?
Old Apr 4, 2011 | 05:44 PM
yes depending on your tire size
Old Apr 4, 2011 | 06:35 PM
Yes mileage can vary depending on gear ratios and tire size as well
Old Apr 4, 2011 | 09:01 PM
echo.
