removal of badges on side and hood of truck
Old Mar 30, 2011 | 12:29 AM
1stGen1990's Avatar
Default removal of badges on side and hood of truck
how do you remove the badges on the side that say w250 or power ram or whatever? just pry them off, an what about the dodge badge on the front of the hood? seems like they would just break. i would like to paint mine and just want to be able to remove and reuse them
Old Mar 30, 2011 | 02:30 AM
01ford_f_350's Avatar
dentel floss do it like your flossing your teeth and it will come off
Old Mar 30, 2011 | 02:04 PM
1989w250's Avatar
I'm not shore about the one on the front . But the ones side have a plastic pin on the back that doesn't come off. I broke them off and used double sided tape to put em back on and they have stayed on for almost three years now.
Old Mar 30, 2011 | 08:35 PM
wellmi's Avatar
Hey this is kind of related anyone know where to get the badges?
Old Mar 30, 2011 | 11:05 PM
big bad diesel 416's Avatar
Site Sponsor
the one on the hood has 3 metal pins that stick through I just used a puddy knife the ones on the side same way
and ya I have some here
Old Mar 30, 2011 | 11:33 PM
chromehound's Avatar
Some trucks side badges had pins others were glued on. If it's glue just pry slowly to remove the badges then get a high quality glue remover that won't screw up your paint and take your time working in small patches but try not to use a razor blade unless you don't mind a bunch of scratches until it's painted.
Old Mar 31, 2011 | 12:52 AM
Begle1's Avatar
This must be really dependent on year.
I just de-badged mine; the front "DODGE" had one metal stud in the center that had a bolt on the inside and two plastic christmas trees on the sides. The side badges were glued on... But there were holes under the adhesive pads.
Old Apr 1, 2011 | 08:31 AM
93_dually's Avatar
i've used fishing line and goo gone on the glue and that seems to work very well.
Old Apr 1, 2011 | 11:21 AM
1stGen1990's Avatar
Ok so I would have to break the pins off and just double sided sticky tape it back on?
Old Apr 1, 2011 | 08:21 PM
1989w250's Avatar
Yes but make shore its waterproof
