fuel mileage question
Old Mar 29, 2011 | 05:21 PM
madcreekfarm's Avatar
Default fuel mileage question
can sticking variable veins reduce your fuel mileage? what kind of fuel mileage do you guys get out of your six-o? I'm getting 14.33
Old Mar 29, 2011 | 08:13 PM
ntmdtr3fan's Avatar
This topic is brought up quit often here. Im sure youll find them if you search. As for MPG it depends. Im running all stock other then a 4 inch turbo back exhaust. If I can keep it under 70 mph or 2k rpm then Ill get roughly 14 to 16 a gal. But once I go over it drops pretty much. This is highway driving. Now for city driving with lots of stop n go and not getting over 40 mph. It drops dramaticly to about 10 mpg.
I just recently posted this on another thread. Must I got with a full tank ( 36+gals topped off tilll you see fuel in filler neck) was about 520 or 540 miles. ( I cant remember) But I average about 360 to 420 per tank.
as for teh vains sticking. Im pretty sure it will effect the mpg. As your using more fuel to get up to spend with a turbo that wont spool completly. I had mine cleaned at ford a couple months ago and I noticed alot better exceleration and just a tad better mpg.
Last edited by ntmdtr3fan; Mar 29, 2011 at 08:13 PM. Reason: Automerged Doublepost
Old Mar 29, 2011 | 08:20 PM
Mdub707's Avatar
13-15mpg here, extended cab short bed 4x4 auto, running tunes all the time (tunes switch all around though).
Yes stuck veins can kill your mileage, but I don't think it's too far off. Ford's are built like trucks, so they're usually a bit heavier than the other offerings out there.
Old Mar 30, 2011 | 10:02 AM
HeavyAssault's Avatar
Current weather temps, current winter blend fuel, and your location make those numbers reasonable. I got additional mods, 6" lift and 35's that get 14+MPG regularly for this time of year.
Old Apr 4, 2011 | 03:01 PM
Yeah, its pretty heavy. I had it on the scales last week and with me in it and a half tank of fuel it weighed 7800 lbs
Old Apr 4, 2011 | 06:55 PM
BigJay's Avatar
10-11mpg, but most of my driving is to/from work, and i have a 4.5ton excursion with oversized tires, and i drive 15 miles to work and it takes me between an hour and an hour and twenty minutes. Basically the worst possible driving conditions. Cross PA turnpike maintaining 65mph the entire way I can get 20.2mpg max.
Old Apr 5, 2011 | 12:17 AM
stackboy6.9's Avatar
i got 18 with my dads dually
Old May 14, 2011 | 09:51 PM
hp325's Avatar
I get around 20 with my F350 4x4 CC dually I have a 6 spd manual
Old May 15, 2011 | 01:07 AM
Little Luke's Avatar
Last two tanks ended up being 15.5 towing 5000 lb at 65 mph half way on a 420 mile round trip. The other was about 17 mpg, thats keeping it on the flatlands going to college on an 80 mile round trip every day and keeping it under 60mph. I think I get about 15 to 16 mpg running around here in the hills though.
Old May 15, 2011 | 12:43 PM
Wince's Avatar
My 2006 4x4 F250 Crew cab short bed is getting right at 17 if I keep it slowed down to 70. Thats off the computer since I have not actually topped it off and then manually did the math on my next fill up.
