KDP
Old Mar 29, 2011 | 09:23 AM
m1ashooter's Avatar
Default KDP
Just as a quick question, is it worth it to spend 65 bucks to TST for their KDP "kit", or better off to buy the crank and cover seal from Cummins and make your own washer?
Old Mar 29, 2011 | 09:37 AM
superbee1970440's Avatar
The timing cover seal kit from NAPA is $43 and it comes with the rear gear case cover seal (which you don't need). Making the tab is easy. There are patterns floating around to make the tab. Just make sure you loctite all the bolts.
Sam
Old Mar 29, 2011 | 04:34 PM
tiremann9669's Avatar
I made my tab too either way as long as you fix it I've heard of taking a punch and peening the hole around the pin also.
51Hudson
10
Aug 5, 2015 12:32 AM
quiksilver1j
Jul 30, 2015 12:41 PM
xj_crawler
Nov 20, 2014 12:28 PM
