possibly a dumb question
Old Mar 29, 2011 | 12:48 AM
dieseljunkiejoe's Avatar
Default possibly a dumb question
new at the whole 12v game and im wondering if the stack kits from grand rock will fit my 92 even if it says 94-98? i just wanna make sure that it all works before i drop all the money on a set of 6 inch bull haulers
Old Mar 29, 2011 | 12:56 AM
prison's Avatar
is it a turbo back? give them a jingle. tell them what your workin with and they should have somethin for you. dont order it without knowing that it'll work
Old Mar 29, 2011 | 12:59 AM
Default thanks
thanks for the heads up it is a turbo back but im thinking they should be able to get me a downpipe
Old Mar 29, 2011 | 01:40 AM
prison's Avatar
is 94 the year the body style changed? if so the kit wouldn't be perfect because it is designed for a different body style. they should definitely be able to get you one. i'm sure we have a vendor here that has them. Have you checked out the vendors here? posting in the request a quote section usually gets a quick response and the best prices. Any vendors that can provide you the kit you need can message you a price. It's a great feature here
Old Mar 29, 2011 | 07:16 AM
Rusty89Cummins's Avatar
yes if they give you a turbo back system for a 94 and up truck the down pipe wont work and if your truck is 4x4 then the transfer case will be in the way oh the tubing that works with a 94 and up truck. ask for just the stack kit and if it comes with the 90* elbow for below get that too. i take it your upgrading to the 4" exhaust for the turbo down so get the right 4" down pipe for your 1st gen. then just go to ur local napa or something and get a strip of 4" exhaust flex tubing the length that you need to connect your down pipe and to the stack kit and two exhaust band clamps. that way you can get up and around the t-case much easier with the flex tubing. oh and depending how far the down pipe may reach underneath you may need to take a few inches off of it to have enough room to get the flex pipe to go on. hope this helps
Old Mar 29, 2011 | 07:25 AM
kingbrad89's Avatar
Careful with how much flex pipe you use if your state has inspections. In Pa we can't use over a certain length of flex pipe.
Old Mar 29, 2011 | 01:22 PM
well thats a bummer.
Old Mar 30, 2011 | 08:51 PM
Default awesome
you guys are all simply amazing, thank you so much for the help!!!! i can see ill be fitting in quite nicely here and i already feel like a part of the family. means alot to have the wealth of knowledge behind me along the way!
Old Mar 30, 2011 | 10:08 PM
white93's Avatar
I'm running a 2nd gen exhaust and the downpipe is the only piece that fit good. The only thing you need to make it work is the cast elbow off a p-pump 12 valve. I posted a picture in this thread about halfway down the first page.https://www.dieselbombers.com/5-9l-r...h-exhaust.html
Dodge2006/5.9
Jul 20, 2015 01:21 PM
torg73
May 11, 2015 03:08 AM
Apr 11, 2015 04:01 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
