5k GSK
Old Mar 29, 2011 | 12:28 AM
Diesel Nutz's Avatar
Default 5k GSK
wondering how streetable a 5k GSK would be? Im in the process of building a new motor for my truck with pulling and daily driving in mind. Ive heard that your throttle peddle gets kinda touchy. Anyone running this setup on the street?
Old Mar 29, 2011 | 01:22 AM
biged681985's Avatar
every one i know that has 5k's say they are a pita to drive with a stick shift. an auto there a lil more manageable, but still real iffy on a DD truck imo
goin by whats in your sig, i think a 4k would be more than enough
Old Mar 29, 2011 | 03:23 AM
Ive got the 4k springs in it already, i forgot to add that in my sig. i was just looking to turn some higher rpms for sled pulling. would it be worth while to put the 5k springs in during the pulling season and go back to 4k's the rest of the year?
Old Mar 29, 2011 | 06:55 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i got 5000k spring modded to 5200 but its a auto tranny. i can see it helping you sled pull but might be crazy to drive on the street.
Old Mar 29, 2011 | 09:58 AM
is everything u got done in your sig? if so, 5 k wont help you. you dont have enough fuel for 5k. my boss has 5x.018 sdx comp dvs and a 75mm turbo and the most rpm he pulled down the track was 4300 rpm.
Old Mar 30, 2011 | 04:03 AM
im in the middle of building a new motor, and want to get my ducks in a row before i finish it. sounds like the 5k's might be more of a pain since this truck is mostly a daily driver. the motor is being put together to hold up to 5000 rpm... balanced, 110 valve springs, hd pushrods, fluid dampener, new rod bolts, titanium retainers and keepers, ect. i think ill stick with the 4k's for now.
ive heard you can get closer to 4200 rpm out of the 4k springs. i dont know if its just tightening them down a couple of clicks more or what? any ideas
Last edited by Diesel Nutz; Mar 30, 2011 at 04:03 AM. Reason: Automerged Doublepost
Old Mar 30, 2011 | 09:28 AM
i have 4ks, in neutral i can hit 4200, but on the street ive only hit 37-3800
Old Mar 30, 2011 | 10:17 PM
thanks for the info fellas
Old Apr 7, 2011 | 12:09 AM
cumminspwr11's Avatar
i have 4ks in my truck but cant get it over 3 unless i keep it locked and out of od and then it barely hits 3200, should i tighten them down a click or two more?
Old Apr 7, 2011 | 03:53 AM
madmikeismad's Avatar
I've heard of people hitting 4300, if you have the fuel to support it. If you don't have enough or you have low FP you will be lucky to see 3500.
