blowby tube
Old Mar 28, 2011 | 11:51 AM
01_cummins's Avatar
Default blowby tube
im debating on wether or not i should clamp that tube off so that it stops blowing oil all over the place. has anybody tried this or has a reason i shouldn't do this? thanks!
Old Mar 28, 2011 | 11:56 AM
1st_gen_puller's Avatar
just get an adapter and some hose clamps and extend it down further..
Old Mar 28, 2011 | 12:02 PM
01_cummins's Avatar
i thought about that but i still don't realy like my oil dripping period
Old Mar 28, 2011 | 12:06 PM
i know what u mean... i just didnt wanna crimp it... thats just me... no real reason..
Old Mar 28, 2011 | 04:10 PM
cummin along's Avatar
I have seen a few trucks with cooling hose routed to the back of the block.
Old Mar 28, 2011 | 06:57 PM
TugBoat's Avatar
its gotta breathe, cant block it off
Old Mar 28, 2011 | 07:56 PM
banditsdiesel's Avatar
i agree 100% with tugboat DO NOT BLOCK IT OFF.
if you block it off the block cannot vent pressure and crank case pressure is a very bad thing it can blow rings off the pistons and do some nasty damage inside the motor
Last edited by banditsdiesel; Mar 28, 2011 at 07:56 PM. Reason: Automerged Doublepost
Old Mar 28, 2011 | 08:40 PM
biged681985's Avatar
if u block it off, the first thing u will do is probably blow out the tappet cover gasket. to replace that gasket involves removing the vp.
the best way to do it is get some pvc or just some rubber hose and extend it to the back of the motor and turn it down. it will make a big difference in the oil u will notice. have it hanging down past the frame a lil, and u wont get oil all over the place. makes a big difference
Old Mar 29, 2011 | 02:34 PM
01_cummins's Avatar
allright thanks a bunch ya'll i'll make sure to do that
Old Apr 3, 2011 | 07:52 PM
02CUMMINS24V's Avatar
I just extended mine down further.. right above front axle and it stopped all the oil from being all over front of the motor
