Long Trip Comin... what oil;s to use?
Old Mar 27, 2011 | 10:09 AM
kelchy82's Avatar
Default Long Trip Comin... what oil;s to use?
movin about 35 hrs away next week.. thought itd be a good time to change some fluids...
to change the tranny oil i just need to drop the pan and change the filter correct?? and that takes dextropn III i beleive?? any idea how many litres its gonna need?
what gear oil should I use in the rear diff and the fron diff?? how much will i need for each one?
thanks guys
Old Mar 27, 2011 | 10:17 AM
wildbill's Avatar
Use 75W-90 in the front and rear diffs (calls for 80W-90), but you won't have to worry about it getting stiff.
On the transmission, be sure it's warmed up a little before you drop the fluid, and be sure the truck is level. When you add fluid, get it to the full mark before you start the engine. Then be to shift into neutral, then add till you get to the full hot mark. Shift into gears periodically and keep checking the level.
al0311
Mar 8, 2016 05:52 AM
torino73
Apr 14, 2015 11:15 PM
dandbmcc
Mar 14, 2015 11:05 PM
cutthroatxxx
Dec 14, 2014 08:15 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
