boost pressure
Old Mar 26, 2011 | 08:00 AM
thedm4778's Avatar
mad boost pressure
Does anybody know what the fact boost pressure on a 06 6.0 is ? Was getting 24-25 then did head studs and egr delete and now only get 19-20 !
Old Mar 26, 2011 | 08:19 PM
20powerstroke05's Avatar
At what speeds and rpms?
Old Mar 26, 2011 | 08:25 PM
thedm4778's Avatar
Default boost
At wot
Old Mar 28, 2011 | 07:04 AM
Mdub707's Avatar
Stock tuning 22-24psi is usually right. How is the truck running? Are you sure all of your connections to the turbo are tight? Usually the up-pipes are a pain in the a$$ to get right on the first try when reinstalling the turbo.
Old Mar 30, 2011 | 08:09 AM
jimrd's Avatar
That is what stock gives 22 24 psi until the plastic coupling came off (LOL) the turbo
Old Mar 30, 2011 | 10:55 PM
thedm4778's Avatar
No leak at up pipes . With or without tuner I only see 19 or 20 I know I was getting 24-25. Turbo was clean
Old Mar 30, 2011 | 11:08 PM
ntmdtr3fan's Avatar
had sticky vaines and only got about 15lbs of boost. Ford cleaned the turbo/vains and it went to 29 to about 32 . Thats gettign on the gas up to about 80 mph. Now its back down to about 24 to 28 max. It always just tips under the 30 mark. Could be faulty guage? I dont know..
Old Mar 31, 2011 | 08:17 AM
Mdub707's Avatar
I can hit 29 on stock tuning now, not sure what has changed with my truck. If I roll in I can almost touch 30, but if you just flat foot it, 22ish. As long as the truck is running ok, I wouldn't worry too much about it. Just because the boost gauge isn't in the same spot doesn't mean the truck isn't running ok.
On my looney tune, I can actually max out my 35psi gauge if I roll into it just right going uphill.
How are you for fuel? Adequate pressure? When's the last time the filters were changed? You can't spool a turbo without fuel!
I'd also check over all of your intercooler boots with a fine tooth comb.
robbyS
Apr 16, 2015 02:22 PM
dango
Jan 22, 2015 04:23 PM
Tsgbk9
Dec 23, 2014 11:54 AM
cameronlee51
Oct 28, 2014 12:33 AM
GreenDieselF
Oct 20, 2014 02:05 PM
