Blow Off Valve
Has enyone ever heard a blow off valve on a diesel truck? I figured if a car's turbo making 10psi sounded cool then a truck at 40psi would sound even better. Atleast give the ricers something to admire. I just got mine in and noticed there is a little more wireing involved that I would have thought but will try to get it all hooked up soon.
aftermarket units, my truck discharges loud enough as it is when i let off it.....
el cheapo http://www.hopupracing.com/kptwhobloffv.html
better http://www.hopupracing.com/tubloffvatys.html
good http://www.rallysportdirect.com/shop...lve-p-568.html
logan those are for gassers..... not for diesels..... those use a vaccum reference to open the valve. when the throttle blade closes it creates vaccume and opens the valve..... diesel's never create vaccume. even if you plumbed a valve into the vaccum pump you'd still have to have a boost pressure line ran to it to keep the BOV closed under boost...... it's perty complicated to get one of those to work on a diesel..... i'm prolly gonna do it but it's gonna take a crap ton of solonoids and relays and different hobbs switches to get right.....
