Truely reliable 400hp towing
Old Mar 26, 2011 | 12:20 AM
95.12v.Cummins's Avatar
Default Truely reliable 400hp towing
Hey yall I’ve done some digging around on here but I’ve gotten bits and pieces of what I’m looking for, I’m curious on what your guys opinions on what it would take to go from a stock 95 Dodge Ram 2500 4x4 5.9 Cummins with the NV4500 trans. I’ve done some mods I’ve taken the #8 plate out for the time being and installed 4" turbo back exhaust with a Aero Flow muffler, my current goal is to have a 400hp truck that is extremely reliable and excellent for towing. Thanks for all the input! Great site!
Old Mar 26, 2011 | 01:57 AM
5.9sledhead's Avatar
I'd start with headstuds for reliability, then plug your wastegate. Check your turbo it may be a wh1c mine was an I have the same pickup it sounds like. Then bump your timing to say 18*. throw in some injectors, 4k govs with exhaust springs and Dvs and you should be there I think. Then your going to have to upgrade clutches like where I'm at right now if you ever have your pump off do the Mack plug its a noticeable gain I just shimmed my plug an it worked great. Oh ya read up on tuning your afc also.
Old Mar 26, 2011 | 07:24 PM
My turbo is a Wh1c. Ive got 60lbs springs on the exhaust side because of my exhaust brake, and a set 4k Dynomite Diesel governer springs I just have to have a sunny day to put them in. My next task is to upgrade the clutch and while I'm in upgrade to the larger input shaft and fix the fifth gear nut issue. Any ideas on upgrading the turbo to keep egt down?
Old Mar 27, 2011 | 12:19 AM
12valvetater's Avatar
Old Mar 27, 2011 | 08:53 AM
Drothgeb's Avatar
If you plan on stopping at 400hp, I would go 5x12s, SuperB(57/65/14), 3 GSK, #100 with a tuned AFC. The B will spool really quick with this combo and has a 14cm exhaust housing to keep it cool while towing.
If you think you may want a little more power, then a 62/65, 62/68 or 63/68 may be best for you.
Old Mar 31, 2011 | 01:30 PM
Don't forget a DD and a big input shaft.
Old Mar 31, 2011 | 01:44 PM
NadirPoint's Avatar
Twins - if you want to use all the power towing, either heavy or in the mountains.
Old Apr 3, 2011 | 08:56 PM
Oh not a horse power gain but do 5th gear while your there mine fell off what a pain in the *** for an easy fix . I'd say twin turbos just cause its fun to brag that you have one more than most
Old Apr 3, 2011 | 11:52 PM
What twins would you guys recomend? Dont just throw up numbers.. When I do my upgraded input shaft and clutch I'll do the fifth gear nut fix. Im just starting to dig into clutchs, any advice on what would be a good clutch?
Old Apr 4, 2011 | 12:15 AM
Industrial Injections or BD's Towing Twins will work great....
