custom lift pump
Old Mar 25, 2011 | 01:40 AM
cumminspwr11's Avatar
Default custom lift pump
i have a stock take off lift pump off a 02 24v that i was thinking about rigging up to use on my 95 instead of my mechanical one, do you guys think i will gain anything from this? im not too concerned with gain but i dont want to hurt my IP, if i do use this pump i will get some remote filter set ups form napa and move my fuel filter down to the frame and probably run two filters
Old Mar 25, 2011 | 02:33 AM
madmikeismad's Avatar
I'm pretty sure that carter pump pushes a lot less psi because the vp pumps require about half the pressure. It won't work. And they aren't very good to begin with, thats why the vp's are always dying.
Old Mar 25, 2011 | 10:26 PM
L6powered's Avatar
Stay away from that type of lift pump. They tend to fail slowly taking the vp with them so I would steer clear. Besides the mechanical one you have now is much more reliable and cheap to replace.
Old Mar 26, 2011 | 03:26 AM
pukie370's Avatar
What about going the other way and puting mechanical on a vp44? just a thought.
Old Mar 26, 2011 | 10:19 AM
davo79's Avatar
Unless you get the can with the lobe for the mechanical pump on the 24v it wont work
Old Mar 27, 2011 | 02:01 PM
L6powered's Avatar
It's easier to shell out the cash for an airdogII or a fass setup.
Old Mar 27, 2011 | 02:40 PM
i was just wondering cause i have one laying around and i hate priming my truck with that mechanical one, i have a fuel pressure gauge so i always know what psi im running, i burn alot of used atf and motor oil so my fuel filters dont last long sometimes and i gotta keep an eye on that stuff
also wondering how the air dogs or fass work on the 12v, i know on the 24vs they are connected to the computer and as throttle increase so does fuel psi but on the 12v there isnt a computer to control it-so does it just run at the pumps max all the time and the ofv regulates the pressure then?
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
