damper proff screw on p7100 pump
Old Mar 24, 2011 | 04:58 PM
12valvedave's Avatar
Default damper proff screw on p7100 pump
hi does anyone have any good ways of getting the factery bolt out of the pump with out breaking anything?
Old Mar 24, 2011 | 05:23 PM
daveO's Avatar
I took a long torx bit and hammered it in. Worked well. Once it was out, I replaced it with a standard bolt.
Old Mar 24, 2011 | 05:32 PM
Whit's Avatar
Site Mascot
and if that doesnt work drill a hole in the middle and use an easy out to remove
I did this once with a left handed drill bit and that in itself screwed the bolt out heheheheeeee
Old Mar 24, 2011 | 06:18 PM
ok thanks guys. what about the other bolts should i worry about them snapping? and what about the plate will tht actully give me more power if i slide it forward?
Old Mar 24, 2011 | 07:14 PM
daveO's Avatar
I didn't have a problem with any of the other ones. Sliding the plate forward will net you a little bit, but not a whole lot. It allows the fuel governor arm to move forward farther, giving you more fuel.
Old Mar 25, 2011 | 04:06 AM
97cummins's Avatar
If you move the plate full forward that will cause your egt's to go up.If you don't have an egt guage i recomd getting one first.
Old Mar 25, 2011 | 06:41 AM
ok. i gotta get tht. how hot should it get? and what is too hot?
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
