ABS and emergency brake stuck on
Old Mar 24, 2011 | 04:22 PM
jdbigblue12v's Avatar
Default ABS and emergency brake stuck on
anyone else have problems with having these lights stuck on
Old Mar 24, 2011 | 05:43 PM
kieron_kohlmann's Avatar
Brake comes on with the abs so its an abs problem. theres a thread in the sticky on how to resolve the anti-lock light.
Old Mar 24, 2011 | 07:51 PM
ok thanks man
Old Mar 24, 2011 | 08:00 PM
flyingcrodeo's Avatar
they stay on if you have a taillight out or wire grounding somewhere to taillights or pull up on your park brake and make sure its hittin the sensor to tell it it's not ingaged, or that sensor is out
Old Mar 25, 2011 | 01:26 AM
big bad diesel 416's Avatar
Site Sponsor
open glove box, remove glove box, locate black box, unplug black box, install glove box, close glove box
issue solved
Old Mar 25, 2011 | 04:48 PM
whats the black box?
Old Mar 25, 2011 | 05:48 PM
Site Sponsor
the ABS brain
Old Mar 26, 2011 | 01:06 PM
i do have a bad wire going to the right tail light but it only grounds out sometimes and i lose reverse light and directional after i hit a bump and the light still stay on. i have absolutely no ABS working. i will try unplugging the ABS and get back to you thanks
Old Mar 26, 2011 | 01:22 PM
Site Sponsor
ABS is for girls the truck stops way better with out it 1st gen abs SUCKS
Old Mar 26, 2011 | 07:38 PM
so true i can stop it alot easier than i can stop my brother jeep with ABS and tht is 2000lbs lighter
