killer dowel pin
Old Mar 24, 2011 | 01:52 PM
big red ram's Avatar
Default killer dowel pin
what is the kdp where is it what does it do and can i do away with it
Old Mar 24, 2011 | 02:44 PM
jdbigblue12v's Avatar
if you have a first gen its not as much of a concern and it is located in the timing case. the pin falls out and falls into the gears and destroys everything. hope this helps
Old Mar 24, 2011 | 02:46 PM
kieron_kohlmann's Avatar
Theres a thread in the sticky if your concerned. its titled fixing your kdp for cheap or something like that.
Old Mar 24, 2011 | 05:11 PM
sweetv8s10's Avatar
Why is it not as much of a concern if you have a first gen?
Old Mar 24, 2011 | 08:27 PM
Edahall's Avatar
Is there any way to check whether it's been fixed without taking everything apart?
Old Mar 24, 2011 | 08:30 PM
prison's Avatar
nope. gotta take the cover off and look at it
Old Mar 24, 2011 | 08:40 PM
ok i'll check it out thanks
Old Mar 24, 2011 | 08:58 PM
fatirishguy's Avatar
I got lucky and I know the original owner and he did the fix in 1995, I also know the kid i bought it from a few years latter and he has not had the cover off. Iam planning on a teardown just to make sure every thing is OK.
Old Mar 25, 2011 | 12:15 AM
sweetv8s10's Avatar
Could someone tell me why its not as much of a concern if you have a first gen?
Old Mar 25, 2011 | 12:56 AM
tltruckparts's Avatar
i believe that was sarcasm, all 12v's are prone to the problem
