wastegate and star wheel
hi i was wondering if anyone could give me the steps on wireing my wastgare shut? its stuck open. and how far should i crank my stra wheel will it ruin my engine or tranny? or what about slideing my stock fuel plate forward i just got the truck less than a year ago
no. transmissions are all different but you should be able to slide it forward without any issues. if you take it out, you might slip a little and don't do more than 30 pounds of boost without doing the heads
ok thanks man big help. do you know anything about the wastegate. mines got a rot hole in it. and i took my turbo off and the wastegate is wide open until i hit over drive then it shuts.
and also is that damper proff screw hard to get off?
Last edited by 12valvedave; Mar 24, 2011 at 12:10 PM. Reason: Automerged Doublepost
well actually, I'm having issues with my wastegate as well. it's not working until overdrive either. I tore into it last night but couldn't get it off and the rain drove me away. maybe i'll try tonight. I'll let you know how hard that screw is
