91 turbo problem
Old Mar 24, 2011 | 10:56 AM
plumbob84's Avatar
Default 91 turbo problem
i have a 91 w250 5spd 4x4 non intercooled 210000 miles my turbo was rebuilt wroung the guy i bought it off of didnt balance it so i have a 1994 turbo for a intercooled truck thats in great shape if i clock the turbo and use new boot then will i jack up my motor im not new to deisels on working on them but i dont know much about performance and swaping stuff out any input is appriciated
Old Mar 24, 2011 | 01:02 PM
Mendomotox's Avatar
your 91 had an hc1 with a 18cm eh housing and that one from the 94 is a bigger hx40 i think. will at least need a down pipe with the hx40 ex flange and you might have to modify your intake too.
downpipe: Source Automotive Performance Diesel
Old Mar 24, 2011 | 01:08 PM
plumbob84's Avatar
i have machine shop capabilities at were i work so i am going to modify it to make it work i would buy the intercooler and piping but im on a very limited budget.
Old Mar 25, 2011 | 06:35 AM
KD93's Avatar
It's an HX35. 12cm2 exhaust housing, and I think a 54mm compressor wheel, if it's stock.
Old Mar 25, 2011 | 08:52 AM
plumbob84's Avatar
you are right i have been doing more reearch if i dont run the intercooler then will the 94 turbo hurt anything i just want to make sure it wont jack it up i have to drive this truck to work everyday and i cant have much down time
Old Mar 26, 2011 | 04:50 PM
tower_ofpower's Avatar
you'll b alright without the intercooler. EGT's would suffer if it were an intercooled truck running without an intercooler but given the fact the truck is non intercooled with a smaller turbo; throwing a "larger" turbo on cant do anything but lower your egt's anyways, you should see some higher boost and reliability wont be an issue. enjoy
Old Mar 29, 2011 | 08:30 AM
plumbob84's Avatar
thanks for the info i will be putting the turbo on and seeing what it will do the old turbo wont spool up now and is blowing oil into my intake tube
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
