450 hp
Old Mar 23, 2011 | 11:42 PM
stackboy6.9's Avatar
Default 450 hp
im doin a cummins swap in my ford.im just wondering what i need to do to make it get up to 450hp.i wana do twin turbo,4k govnor springs, injectors, fuel plate, timing,pump all the way up.3 1/2 inch down pipe to 5inch stacks.
and head studs.and air intake
Last edited by stackboy6.9; Mar 23, 2011 at 11:42 PM. Reason: Automerged Doublepost
Old Mar 24, 2011 | 11:14 AM
94 12valve's Avatar
your not going to need twins for 450 rwhp in a cummins ... in a powerstroke you would but not in a cummins
Old Mar 24, 2011 | 12:13 PM
12valvetater's Avatar
a 63/68-12 would be a fun street trubo for that power level. Should clean the smoke up real well.
Old Mar 24, 2011 | 12:50 PM
if i wer to use twin turbo how much more power would i get.and alright thanks for the info.what injectors shuld i use and wat fuel plate
Old Mar 24, 2011 | 08:00 PM
Depends on how big you size your turbos...
Old Mar 24, 2011 | 08:01 PM
94 12valve's Avatar
and in this case bigger is not always better
Old Mar 24, 2011 | 08:56 PM
monster12valve's Avatar
62-68-12 over s475. 600hp is easily obtainable
Old Mar 24, 2011 | 11:38 PM
EasternAggie's Avatar
If hes just wanting 450hp I would keep the 35 and use it over an HT3B. Would be cheaper that way. I would say #100 plate full forward and 5x.014's for that turbo setup. What year engine will you be using? You might want to change DV's also if you have 131's in right now.
Old Mar 25, 2011 | 04:55 PM
its a 94
Old Mar 25, 2011 | 05:30 PM
If Im not mistaken you have 131 DV's then.
