Oil and thick grease build up???
Old Mar 22, 2011 | 03:54 PM
KillStroker's Avatar
Default Oil and thick grease build up???
Ive cleaned this mess up for a while now but it comes back It gets to be like thick grease not oil but it spins up on hood, radiator, fan and down on frame. Is this the kit that solves that.
88-02 Dodge 5.9L Cummins Crank Case Breather Relocation Kit
I know from the site it looks to be plain english? But it refers to oil and wanted to know if any of you can give me some more info. Thanks
Old Mar 23, 2011 | 01:15 AM
dukeboy_318's Avatar
yeah itll help alot. I had the same issue, you could also just run a longer hose from the blow by bottle.
Old Mar 23, 2011 | 11:39 AM
1st_gen_puller's Avatar
i just got a fitting 2 hose clamps and a longer hose... took the whole res. off... does the job and its less clutter in the compartment..
Old Mar 23, 2011 | 02:03 PM
Awesome, I will look into that
Old Aug 10, 2011 | 02:49 PM
TORQUE's Avatar
Just curious Stroker did you try that?
Old Aug 10, 2011 | 06:17 PM
mines been on for about a year... not a problem yet... and soled it..
Old Aug 12, 2011 | 12:42 PM
I went the cheaper route and just extended tube.
greasesheik
Nov 29, 2014 05:01 AM
