Flywheel Machining
Old Dec 8, 2007 | 06:50 AM
Super Dave's Avatar
Default Flywheel Machining
I ordered a CON OFE for my NV5600 truck. SB says to have the flywheel resurfaced, and with the pilot bearing upgrade I'll need to enlarge the hole.
I plan on doing the swap myself and I am planning on two days (I figure I will install the AirDog and diff cover all at the same time).
I have access to a lift and tall transmission jack so it should be fairly easy, but I have to have the machine work done on the flywheel.
How much should this work cost at an automotive machine shop? If I walk in, how long will it take them? Should I call before I start the removal so they know I'm coming down? Will I need shims made to correct for whatever material they remove?
Thanks
Old Dec 8, 2007 | 08:57 AM
Whit's Avatar
Site Mascot
heres what I now bout it
the flywheel isnt flat............dont let any ol machinest do this cuz its different and he could screw it up
yes the pilot bearing will need machined to recieve the new pilot bearing
I dunno bout cost but should be say 2 hrs worth
no shims needed
you have specific instructions that came with yer SB clutch.....make sure to get them to the mackinest and make damn sure he understands them
Old Dec 8, 2007 | 10:55 AM
LOGANSTANFORTH's Avatar
a good clutch and joint shop shouldnt be no more than a 3 hour turn around unless they are swamped, probably wont cost anymore than 100-150 at the most.....
Old Dec 8, 2007 | 02:14 PM
saab9k's Avatar
Is replacing mine this week end, bought a new flywheel, is going to sell mine after it is resurfaced, do it often on tractor flywheels.
Old Dec 8, 2007 | 02:30 PM
Super Dave's Avatar
That long huh? More than I figured. I was figuring an hour at shop labor prices. Oh well, its only money.
Old Dec 10, 2007 | 09:16 AM
staarma's Avatar
Mine cost $65. Don't let them "resurface" it. It needs to be ground. The stocker has a taper to it that needs to be taken out is all. I agree, take it to a place that knows what they're doing. Southbend has an installer lookup on their web site. I would look there first for a guy near you.
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Dec 11, 2014 07:29 PM
