1992 12v lights pulse at idle
Old Mar 21, 2011 | 10:12 AM
JoeNelson's Avatar
Default 1992 12v lights pulse at idle
when the truck is at idle and even driving the lights pulse what could this be is it a common problem???
Old Mar 21, 2011 | 11:12 AM
Levi Miller's Avatar
clean your ground wires and make sure there all connected that should fix the problem i relocated the one that goes from the battery to the side of the truck down on the frame
Old Mar 21, 2011 | 11:56 AM
Edahall's Avatar
Mine also did that and turns out there was a bad connection in the input wire that goes to voltage regulator.
Old Mar 21, 2011 | 09:23 PM
austinward's Avatar
definitly check all yoour ground wires i had the same issue with my truck but i also had a short under the dash that was blowing fusible links it was a nightmare but yea i would definitly check all your ground wires and make sure there all tight cause these old trucks are rattle boxes
Old Mar 22, 2011 | 12:40 AM
sweetv8s10's Avatar
My truck is doing the same thing so if you figure out what it is let us know because I have checked every thing and I still can't find so good luck.
Old Mar 22, 2011 | 07:18 AM
Rusty89Cummins's Avatar
mine was the voltage regulator. eventually it went and i was stuck on the side of the road.
Old Mar 30, 2011 | 11:54 AM
abigassbowtie's Avatar
mine did that too and when the voltage regulator went i was a few hundred miles from home and poked and prodded around with the alternator till it was charging (by grounding one of the terminals on the alternator) but it bypassed the regulator almost got home before it let the smoke out of the hole electrical system (whoops) so I guess Its time to swap the motor into a better truck
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
