loping at idle
Old Mar 20, 2011 | 08:58 PM
HAYMAFIA's Avatar
Default loping at idle
i have a 96 215 pump, with 4k gov. springs. the idle is too low now 400 rpm. it's real lopey, kinda missing, until about 800 rpm. then it clears up. if you rev it in neutral it revs all the way up but it sputters all the way up. don't seem to do it while driving. plenty of power. do yall think it could be timing? no air getting in fuel. i've tried everything i can think of.
Old Mar 20, 2011 | 09:04 PM
Red_Rattler's Avatar
High Tech Redneck
when u free rev and white smoke?
Old Mar 20, 2011 | 09:11 PM
madmikeismad's Avatar
Also, whats your fuel pressure at?
Old Mar 20, 2011 | 09:24 PM
HAYMAFIA's Avatar
haven't checked fuel pressure. not really much white smoke mostly black. it doesn't seem to matter hot or cold does same thing
Old Mar 20, 2011 | 09:32 PM
Lil Red Express's Avatar
You can adjust the idle. Should be about 700rpm. Sounds like your timing has slipped. my old 97 did the same thing. Adjusting the timing to about 16* fixed it.
Old Mar 20, 2011 | 09:38 PM
High Tech Redneck
if its not smokin white i wouldnt suspect the timing, how many miles on the injectors?
Old Mar 20, 2011 | 09:43 PM
HAYMAFIA's Avatar
thats what i was thinking. i need get my brother to come down he has a snap on timing kit.
i put different injectors in and didnt change anything. what about the governor springs do u think they need adjusted
Daylon
Aug 23, 2015 11:01 AM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
