NV4500 conversion
Old Mar 20, 2011 | 03:41 PM
tow_mirrors_in's Avatar
Default NV4500 conversion
First off this is my first post. I want to thank all you for previous questions and answers. It has been a great help and education. I have a 95 4x4 automatic and have a few questions about an nv4500 swap.
1] if i chose to get a 98 and up nv4500 will the hydraulics from a 95 manual work or will i have to get the 98 and up hyds? will the pedal assembly and firewall mount be the same?
2] Mine being a reg cab 4x4, will the plastic shifter console on say a 99 and up fit correctly instead of just shifter boots from the previous years? any input would be greatly appreciated.
thank you
Old Mar 20, 2011 | 04:23 PM
davo79's Avatar
You'll want the old boots the 98 and up were different. I believe also you'll want a 95 or 95 guage. Cluster and steering column the pedal assembly is the same. The only advantage to the 98 and up 4500 s is the ability to put a short throw shifter on it the top plates are different. 5th gear still falls off so get that fixed
Old Mar 20, 2011 | 10:34 PM
I appreciate your response. i was wanting to buy a reman 4500 from a 99 4x4. my main reason for that year was my dealer who i am purchasing my trans from said that the newer trans had better syncros. He could be wrong and i am also wanting to put a short throw shifter in. But from my understanding the hrydrualics are different. My year model truck is a 95. i have the twist in slave cylinder and i think the newer modles are bolt in on the firewall. i guess what my main question would be, will i run into any problems putting a 99 4500 in a automatic 95 as far as hydraulics?
Old Mar 20, 2011 | 11:32 PM
davo79's Avatar
You shouldn't but do yourself a favor and by the HD kit its well worth the money and get the 99 kit so you don't have any problems
CGwill
Jan 26, 2015 02:10 AM
learningdiesel
Diesel Engine Conversions
Dec 17, 2014 11:06 AM
jdcarter
Nov 29, 2014 11:31 AM
sotomo
Nov 24, 2014 07:29 PM
gixxerman1000
Nov 2, 2014 07:53 PM
