lowering my EGTs???
Old Mar 20, 2011 | 03:24 PM
crazycrawler32's Avatar
Default lowering my EGTs???
i have a 98 12v with a #5 plate starwheel maxed and the brass elbow... i tow a lot with it and the EGTs get hott going up hills bout 1200F depending on the hill and the load... whats a way to lower the temp without downsizing my fuel...also it seems to build the most power only while in overdrive 45mph and up how can i get all that power sooner?? thanks....
Old Mar 20, 2011 | 03:45 PM
12valvetater's Avatar
If your converter can take it put a lockup switch on it.
Old Mar 20, 2011 | 09:04 PM
BRE's Avatar
BRE
Little timing may help. Some exhaust would help depending on what you have.
Old Mar 20, 2011 | 09:39 PM
Lil Red Express's Avatar
Is your pyro probe in the manifold or the down pipe? If its in the mainfold then seeing 1200 is not that bad. I used to sustain 1450 on my old 97 towing long hills, that truck has over 400,000 miles now on the original injectors and pump. Never hurt anything except transmissions. I see 1400+ on my 02 every day.
Like said before some timing would help. Bigger exhuast if its still stock.
Old Mar 20, 2011 | 09:50 PM
5.9Bronco...eventually's Avatar
water injection
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
TheDirtyDozen
Nov 16, 2014 02:56 PM
