dash
Old Mar 19, 2011 | 03:35 PM
dillion's Avatar
Default dash
all of a sudden my gauges stoped working. any help at all, checked all fuses and swaped relays
Old Mar 20, 2011 | 04:32 AM
davo79's Avatar
Check your crank position sensor its located above your harmonic balancer
Old Mar 20, 2011 | 10:15 PM
HAYMAFIA's Avatar
which gauges? there is a master fuse under the hood that causes your alternator not to charge. also if your tach doesnt work then your alternator wont charge either. there is a fuse in the cab that controls the gauges. i believe it is the cluster fuse
Old Mar 21, 2011 | 06:27 PM
dillion's Avatar
i pulled my dash out to replace the clear cover, put it back together and my speedometer,tach,alt, and temp will not do anything. oil pressuer and fuel gauge still work
Old Mar 22, 2011 | 01:22 AM
davo79's Avatar
Sounds like one of the plugs on the cluster isn't plugged in all the way
mike350fordpower
Jul 17, 2015 08:51 AM
casper83
Jun 29, 2015 07:37 PM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
Andy81
Jan 28, 2015 02:53 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
