turbo education
Old Mar 19, 2011 | 02:18 PM
cumminspwr11's Avatar
Default turbo education
my current turbo is a hx40 compressor with a hx35 exhaust fan and 14cm housing, im wondering if putting a 40 exhaust fan it would improve my spool up and boost levels? bigger fan=more surface area? i know i would have to get the housing machined to fit over the fan, can anyone with a lave do that? or do you really have to know what your doing?
Old Mar 20, 2011 | 12:42 AM
12valvetater's Avatar
Put the 40 turbine in a 12cm exhaust housing, and let the good times roll.
As far as the machining goes anybody with a lathe can do it. Just takes some fitting to get it in there.
Last edited by 12valvetater; Mar 20, 2011 at 12:42 AM. Reason: Automerged Doublepost
Old Mar 20, 2011 | 10:35 AM
you think a 12 would be ok with my setup, even if i wanted to go to 191s or 024s soonish?
Old Mar 20, 2011 | 12:36 PM
The 40 turbine is bigger and flows better. Open up the wastegate so both sides get regulated and have fun. Also when i've machine housings to take bigger wheels it opens them up a little big so its not as tight as it was. If you wanted to hook up a drive pressure gauge to check that wouldn't be a terrible idea.
Old Mar 24, 2011 | 12:57 AM
davo79's Avatar
Don't do 024s do 022s they flow like a laser cut with way less heat. And an hx40 is not a good choice the shafts twist or break when they bark the 35/40 hybrid is an ok setup if you want the flow of a 40 and a fast spool go with the he351 ce of an 04.5 to 07 common rail that's what I run
Old Mar 24, 2011 | 12:15 PM
i know about the shaft issues with the 40s, i only make the turbo bark when i want it too or some tard is driving my truck, my current 14 is a non wastegated housing and if i went to a 16 it would probally be non gated as well, the he351 was another option i was considering, will that turbo bolt up to a stock 3.5 v-band exhaust pipe?
Old Mar 24, 2011 | 03:33 PM
davo79's Avatar
Nope you'll have to mod your downpipe and ice tube but its well worth it
Old Mar 25, 2011 | 09:22 PM
you think i will notice that much over my current turbo huh? my 40 is a 60/60/14 divided and the he351 is 60/60/9 non-divided right? which makes it about an 11 divided
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
