valve adjustment help
Old Mar 18, 2011 | 07:50 PM
big red ram's Avatar
Default valve adjustment help
need step by step instructions so i can do a overhead open to all tips and tricks please keep in mind this is my first time doing this are their any special tools needed
Old Mar 18, 2011 | 07:57 PM
ltr450's Avatar
just feels gauges and a screw driver and openend wench.
1. Find top dead center for #1 cylinder on the compression stroke. (rocker on exhaust cylinders #1,3,5 and Intake on cylinders #1,2,4 should be loose)
2. Take a feeler guage, you'll need 2 different ones, exhaust requires a thickness of .020" and intake requires a .010" thickness. Slide feeler inbetween rocker and valve stem tip
3.ONLY ADJUST THE VALVES INDICATED ABOVE(refer below for rest of valves). Loosen lock nut 13mm or 14mm not sure someone please correct me. Then use flathead screwdriver to turn adjusting nut till there is a slight amount of drag on the feeler gauge.
4. Once it slides with some drag, tighten lock nut and recheck with feeler after tight.
5. Once the intake valves on cylinder #1,2,4 are set to .01" and exhaust on cylinders #1,3,5 are set to .02". Rotate the crankshaft 360* from no. 1 TDC. Then do the remaing valves the same way as above. (Intake on cylinders #3,5,6. Exhaust on Cylinders 2,4,6.
Old Mar 18, 2011 | 09:24 PM
thanks for the help but how do i know i have #1 on tdc
Old Mar 22, 2011 | 11:57 AM
daveO's Avatar
Like it said in step one, rocker on exhaust cylinders #1,3,5 and Intake on cylinders #1,2,4 should be loose. You could also use the timing pin if yours hasn't broken off. The timing pin is located at the back of the gear housing and below the injection pump. Fitting the timing pin into the hole in the crankshaft is tricky, watch the valve train until the #1 exhaust valve closes, then turn the crankshaft about 90 degrees. If the timing pin will not engage, spray it with some penetrating oil to loosen it.
Old Mar 23, 2011 | 08:42 PM
ok thanks for the help
Old Mar 25, 2011 | 01:34 AM
big bad diesel 416's Avatar
Site Sponsor
Read the link and the post set to those specs if you want to go fast
http://www.thedieselpump.com/index.p...ve-adjustment/
RA113024
Mar 13, 2016 07:42 PM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
woodsman27
Oct 26, 2014 02:13 AM
