stalling
hi
i have a 04 dodge 2500...cummins 5.9
my truck will stall at a idle and is sometimes hard to get it started again.diesel is clean,no water in the filter and its clean.i had a vibration a month before that but stopped that same day.
any help would be great
hi Whit
sorry i dont have the fuel presures but the filter is good...2-3 months old.i have no check eng light on...will it store codes with out the cel coming on? the stalling started 2 days ago,havnt done much for tests yet.dosent seem to have any performace issues just stalls at a idle (like the key is turned off....no sputtering to a stall.
ok i will check for codes...thank you so much for that info...
this is the code i got off the dash...p 0628
if its like my fass it came with all new bigger rubber lines to bypass all factory main line and had to drop my tank and drill a hole in my tank and drop the new suction pipe in thats how mine is so im sure yours will be the same
