85 6.2 gp controller
Old Mar 17, 2011 | 12:19 PM
856.2beast's Avatar
ATTN 85 6.2 gp controller
hello all got a problem with my controller i try to cycle plugs and at end of cycle it does not click off instead stays makeing a shorting sound stops and im able to fire her up. Could it be a bad connection or is controller going bad? Also previous owener has by pass hooked up so should i just let it go bad will it mess up anything else? or bite the bullet and spend the 70 bucks that i dont got . thanks all for any advice: warlocks with help i will be WINNING gotta laugh @ mr sheen
Old Mar 17, 2011 | 12:51 PM
Crazy's Avatar
sound bad relay they where know short and stay on just like old ford relays glow plug system that why they ran buy pass switch
for12.00 get new one
Old Mar 17, 2011 | 01:00 PM
856.2beast's Avatar
i proly should let it be then cause it has bypass installed till i get cash to fix it will anything else get messed up? or do i just verify which glow plugs are in there ?
Old Mar 17, 2011 | 01:04 PM
Crazy's Avatar
well if the controller not shutting off you going cook the glow plugs
Old Mar 17, 2011 | 01:26 PM
856.2beast's Avatar
i think it is shutting off the indicator light gets dim when controller makes a shorting sound lasts for a couple seconds then stops and is ready to start.
Old Mar 17, 2011 | 01:53 PM
Crazy's Avatar
take test light to glow plug make you don't have power their
steed
Basement Enterprises
Apr 7, 2015 04:07 PM
jedder21
Mar 7, 2015 09:47 PM
Caveman94
Dec 8, 2014 12:21 PM
dave nh
Oct 21, 2014 03:14 PM
