Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Pulling Question
Old Mar 17, 2011 | 09:31 AM
DanLowe's Avatar
Default Pulling Question
Guys and Gals, I've been scouring this section of the forum looking for tips on pulling for newbies...can't find anything. If someone can come up with some tips please post...looking for what gear, 4 low or high, what setting on the Quadzilla ADR with the 3000 tune, any help would be great. Truck is in the sig.
Old Mar 17, 2011 | 10:35 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
you will be in low range for sure. they are several videos on here including mine.
Old Mar 17, 2011 | 10:49 AM
DanLowe's Avatar
Videos on pulls, or vids on technique?
Old Mar 17, 2011 | 12:25 PM
diesel pap's Avatar
videos on pulls.
Old Mar 17, 2011 | 12:32 PM
Red_Rattler's Avatar
High Tech Redneck
put in drive lock out od out 4lo drive it like you stole it
Old Mar 17, 2011 | 12:55 PM
DanLowe's Avatar
Thanks for the info guys.
Old Mar 17, 2011 | 06:42 PM
diesel pap's Avatar
yeah dan, i forgot to tell you to lock the overdrive out.
Old Apr 26, 2011 | 11:36 AM
TheBigDeOGE's Avatar
u need to build some blocks in the rear if its legal in your class. here is a pic of what i'm talking about.
these go where your rubber bump stops are between axle and frame on the back. if you need a set i can make u some. but they arent too bad to make. and if you plan on pulling alot a weight bracket up front will help also.
just get some 12" receiver hitch tubes from tractor supply and weld to frame and make you a bracket.
hope this helps
Brclouse
Nov 18, 2015 08:44 AM
oneloud59
May 16, 2015 10:00 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
