What Psi are you getting at Idle with A/F Pump
Old Mar 16, 2011 | 09:25 PM
KillStroker's Avatar
Default What Psi are you getting at Idle with A/F Pump
Just Installed an Airdog 150 with a DS V im getting 33 psi at Idle? What are you guys getting? Whats normal Operating psi idle/wot? Thanks guys
Old Mar 16, 2011 | 10:26 PM
Benjamin's Avatar
Bombardier
you might have the wrong Airdog model, IIRC the 24 valve motors require HALF that pressure where the 12 valve motors require 30+ psi....
Old Mar 16, 2011 | 10:35 PM
tburke's Avatar
If it is adjustable I would set it at 18-19 at idle and it should not drop below 10 at WOT
Old Mar 17, 2011 | 12:06 AM
banditsdiesel's Avatar
you need to turn that down quick. that much presure will damage a vp just as bad or worse than running it low. it needs to max at 20 and go no lower than 10-12. if its not adjustable it has a bleed off spring that is under the return line that needs to be changed to a lower set spring.
Old Mar 17, 2011 | 06:39 AM
Thanks guys.
Old Mar 17, 2011 | 07:15 AM
RAW's Avatar
RAW
23-24 at idle, 21-22 cruising, and never drops below 18.
Old Mar 17, 2011 | 07:47 AM
Well the sensor that comes with the edge is not plugged in. So it must be getting that 33psi from the ECM deusch connection????. I ordered that 1/2 tee from Vulcan performance to splice into the line for an accurate reading. Anyone else running this. I ran into this problem running the AD 150 you rplace the pump banjo which you cant run the sensor I put the sensor on the AD150 but the edge wire harness wont reach, so i bought the tee.
Old Mar 17, 2011 | 07:58 AM
RAW's Avatar
RAW
The ECM has no sensor for fuel pressure. The Edge must be displaying the calculated PSI of an open sensor.
Old Mar 17, 2011 | 10:00 AM
01quadcab's Avatar
yeah if it's not plugged in I think it defaults to that. I can't remember. but plug it in and keep your vp happy so you know what its getting
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
