Alignment
Old Mar 16, 2011 | 07:43 PM
1stgenSappy's Avatar
Default Alignment
My pickup needs to be aligned pretty bad is it possible to do it myself? I hate taking it to town to get fixed if I can do it mysleft!
Old Mar 16, 2011 | 09:14 PM
wolfsburgdiesel's Avatar
you can make a rough toe adjustment by tape measure, just measure from side to side, front and back of the tire, but be sure you use the same contact points, as far as camber/caster unless youre pretty good with dgree wheels and some algebra, id recommend getting it done at a good alignment shop
Old Mar 16, 2011 | 09:52 PM
kieron_kohlmann's Avatar
Just make sure you take it to a reputable alignment shop. most places "set the toe and let it go". Be sure they adjust caster/camber, and ask for a print out of the alignment.
Old Mar 16, 2011 | 10:04 PM
pukie370's Avatar
i agree, i have had many shops set toe and pull of rack, so i ask to see chart and if not in midle of recomended setings ask to put back on rack and adjust. I had a toyota that ate the inside of tires and after 2 alignments i got the good guy that spent the time to get right.
ramrunner01
Apr 27, 2015 12:01 PM
ajwright64
Feb 17, 2015 10:08 AM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
