leaking water
Old Mar 15, 2011 | 11:31 PM
staylorw250's Avatar
Default leaking water
Hi my name is skyler and i'm new to the site I just bought a 89 w250 727 and I have to say it's awesome except one thing. I was cleaning it out the other day and i noticed that under the floor it looks like someone took a hose to it it was soaked I was curious if these have a weakness of leaking water or anything it's also soaked in the corners behind the seat any advice would be great
Old Mar 16, 2011 | 12:11 AM
901stgen's Avatar
Heater core maybe
Old Mar 16, 2011 | 02:16 AM
Mike337's Avatar
Look between the doors and your front fenders.....
Cowl Fix - Diesel Truck Resource - Wiki
Old Mar 16, 2011 | 06:58 AM
white93's Avatar
Its totally normal 1st gen behavior. Check what was mentioned above and also the windshield gasket, roof rot, and the vent down by your feet on the drivers side.
And since there is water behind the seat, check to see if it has holes bored in the roof. Mine was like that and I had to use silicon to fix it.
Old Mar 16, 2011 | 08:56 AM
allright ill be sure to look into those thanks for the advice
Old Mar 16, 2011 | 06:29 PM
crazy clem's Avatar
cargo light gasket on regular cabs can make behind the seat a swamp
Old Mar 17, 2011 | 07:12 AM
cummins_guy's Avatar
if you have a sun visor mounted to your roof, the screws that hold it on, leaked for me, and I had one cab light were the gasket was bad.
and I forgot about the brake cable that comes in from the floor, my rubber gromet was missing causing water to come in ever time my tires splashed water
Old Mar 17, 2011 | 09:42 PM
alright thanks for the replys I will check into these suggestions (hopefully before it rains again) I don't want the cab rotting out from under me I was thinking about taking the seats and floor mat out and spraying the bedliner in a can down on it
klein444
Mar 8, 2015 08:19 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
yams
Dec 7, 2014 12:51 PM
mpcampers
Dec 4, 2014 08:24 PM
Stox5225
Nov 18, 2014 01:04 PM
