another timing ?
Old Mar 15, 2011 | 10:29 PM
joshwebb609's Avatar
Default another timing ?
I have a 92 w350 with a 215 hp p pump with all the free mods ? Is! Would I gain from turning the timing up?
Old Mar 16, 2011 | 03:04 AM
pukie370's Avatar
what mods? and is pump stock?
Old Mar 16, 2011 | 08:27 AM
Default all free pump mods
Pump has plate,shimmed Gs,screws turned up all the way stock turbo for now thanks
Sorry NO plate
Last edited by joshwebb609; Mar 16, 2011 at 08:27 AM. Reason: Automerged Doublepost
Old Mar 16, 2011 | 02:03 PM
BRE's Avatar
BRE
Wanna specify screws turned up all the way? Also if your not running a plate you could benefit some from doing afc mods.
Advancing timing will give you more top end power and less bottom end. Typically helps lower egts a litte depending on the setup.
Old Mar 16, 2011 | 06:13 PM
Default all the free mods
Plate out, AFC ff, star wheel maxed, gov springs shimmed, maybe more my friend helped me, well basically he did it he's teaching me its my first diesel thanks for the help!
Old Mar 17, 2011 | 01:55 PM
BRE's Avatar
BRE
I would look into doing the afc mods and tuning that and maybe a mack plug. The timing isnt really just a jump up and do thing. You need special timing tools and requires some patience.
Old Mar 18, 2011 | 02:13 AM
EasternAggie's Avatar
And from what I understand should help mileage too.
Old Mar 18, 2011 | 06:24 AM
BRE's Avatar
BRE
Will increase some depending on the tune and the drivers habits.
Old Mar 20, 2011 | 12:57 AM
You drive around with a heavy enough foot not much is gonna help
Some of the characteristics for advanced/retarded timing can be found here at the bottom of the page
Diesel Timing
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
