Tranny problems
Old Mar 15, 2011 | 07:17 PM
Strokethis04's Avatar
Default Tranny problems
Whenever i put it in drive or reverse it takes a second then kicks pretty hard into gear.
Also ill be driving along with less than half throttle and it acts like it kicks into neutral and the RPMs rev up.
Old Mar 15, 2011 | 08:01 PM
chickbunker's Avatar
Sounds like what my tranny was doing. Before the valve body blew and took out my tranny.
Old Mar 15, 2011 | 08:06 PM
is there anything i can do, so the tranny doesnt go?
Old Mar 15, 2011 | 08:14 PM
not the expert but would say a tranny service could help. maybe some other members might have other options. Mine also started flashing tow haul which put it into limp mode.
Old Mar 15, 2011 | 08:15 PM
thats exactly what mine is doing
Old Mar 15, 2011 | 08:27 PM
get the truck on a computer and see whats happening in the tranny i left mine go to long and gummed up the whole tranny, burnt out the clutches clogged the torque converter and cost me 6500
Old Mar 16, 2011 | 06:35 AM
spelt22000's Avatar
From past experience, servicing a "crippled" tranny "can" turn out to be the worst thing you can do. I am no expert on this either but i have found that when changing fluids in a questionable trans. you are also flushing away the dust -gunk that has stuck to your clutches over time helping them still engage.
I'm sure there are folks on here that can give you a better recommendation but, until i knew the exact problem i would not change the trans fluid. It could be something as simple as one of the solenoids in the trans.
Old Mar 16, 2011 | 07:08 AM
Mdub707's Avatar
Sounds like direct drive is going out. Don't think there is much you can do at this point...
Old Mar 16, 2011 | 10:19 AM
powerstroke74's Avatar
Same thing happened to me truck kept goin into limp mode then bout a week later tow haul was flashing by then it was too late tranny was shot. Not much you can do at this point. Check the fluid mine smelt like it was burning
Old Mar 16, 2011 | 04:34 PM
Thanks for the feedback, its weird now its not doing anything. Its like it has it moments. This morning it did it the whole way to where i was going. Then it ran perfectly fine on the way home. Thank god my brother in-laws father has a tranny shop and they are going to check it out for me.
