Strange noise
Old Mar 16, 2011 | 04:48 PM
Matt5005's Avatar
Default Strange noise
So I am not sure if this noise has always been there and haven't noticed it our if it is new but around 2100 to 2300 RPMs on my 06 CTD there is a metalic knock/tap. Its not real loud and it only seems to do it when it is not under a load, like driving down the highway or when you are ready to shift gears. Truck has 96,000 on it, smarty intake and exhaust. Just me being crazy or something to worry about. thanks for any help.
really no one with any suggestions, it sounds like it is coming from the right side. I have to take a 4000 mile trip soon and would really like to know if it is something to be concerned about
Old Mar 17, 2011 | 07:02 AM
steved's Avatar
Sounds like injector rattle to me...or CP3 timing gear slap.
Old Mar 17, 2011 | 06:36 PM
Matt5005's Avatar
OK how do I check for this and how serious is it?
Old Mar 18, 2011 | 03:32 AM
Sirwrenchiezolot's Avatar
Does it have the stock clutch? u check all ur u joints and carryier baring if ya hav one?
Old Mar 18, 2011 | 04:55 AM
Matt5005's Avatar
still stock clutch. Joints and barings are good. Seems to go with the RPM's it is not loud, but I started hearing it and can't get it out of my head. A friend of mine told me it was cummins clatter. I don't know so I am asking.
Old Mar 18, 2011 | 05:15 AM
Well there could be a possabilty of the flywheel going bad its a dual mass and when they go bad they make noise and vibrate. I upgrade to a south bend dual disk so i can do other mods.
i still have my stocker in a box and its still good it doesnt have that many miles on it so if you find its your issue and dont wana shell out the cash for a new one pm me
Old Mar 18, 2011 | 07:03 AM
steved's Avatar
Injector rattle typically happens as the injector wears, or if timing and pressure are added. Mine rattled for 40k before finally dying...I got a bad batch of water. Cruising down the road, it will sound like pinging in a gasser...not real loud, but definitely there.
Old Mar 18, 2011 | 06:40 PM
Matt5005's Avatar
THATS IT not loud, just kinda there but not there under load or a pull. as for the clutch, it is in the process of taking a poop. Gonna order a S.B. or a Volaro "SP?" it almost sounds like a valve rattle but between 2100 2300rpms. Can I check injectors or see which one is rattling any way? truck has 96000 on it gonna adjust the valves when I do the clutch. Thanks for all the help. I am not up on the common rail truck, I have spent most my time with farm tractors and construction equipment. I am very thankful for all the insight, please keep it coming, I wanna learn.
Old Mar 19, 2011 | 05:57 AM
Love my southbend
Old Mar 20, 2011 | 09:44 PM
you narrow it down yet?
