Looking for horses...
Old Mar 15, 2011 | 03:00 PM
angelic0-'s Avatar
cool Looking for horses...
My Uncle got his 6.5 K1500 today...
Knowing it only has 180 horses we're looking for a few more...
I know this will be a lot harder quest than with my 2nd gen Cummins...
What can we do for a little more, for a little less ($$$) ???
How much boost can these 6.5 take and how do you advance timing on these IP?
How much boost are we seeing STOCK, and are these Borg Warner turbos good for anything over OEM ?
Old Mar 15, 2011 | 05:35 PM
Crazy's Avatar
1) start off buy moving PMD to front bumper with heat sink
2) get set gauges
3) get new exhaust with 3" dp to 4" back and cross over pipe
4) turbo master on set boost 10psi stock chip or ECM and then delete vacuum pump the belt size will be 1 inch shorter
5) get chip or reflash ECM depended on yr of truck
6) set the pump -1.94
Stock boost 8psi it hit 10psi for sec. with chip or reflash ECM you can turn up to 15psi will be max
if not 97+ yr get 97+ air filter set up
if injectors over 100,000 miles get new one have pop test and set for 2300
Old Mar 15, 2011 | 08:01 PM
Woody35's Avatar
2) get set gauges
x2 but you dont need a turbomaster. stock vac system runs better with a proper tune and properly running vac system imho
Old Mar 15, 2011 | 08:23 PM
angelic0-'s Avatar
where will that lead us ??? 250ish hp ???
Truck is a 1998 model with new IP, injectors and lift pump !
Old Mar 15, 2011 | 08:29 PM
Crazy's Avatar
call Bill Heath he nice guy to talk to he tell what you may get out it
Performance Upgrades for GM 96-01 6.5T
Old Mar 16, 2011 | 12:28 PM
Woody35's Avatar
probably around 250 at the crank not the wheels
Old Mar 16, 2011 | 03:32 PM
angelic0-'s Avatar
what would we need for 300horses @ crank ???
MarineDieselUSA.com Supercharger kit ?
I've seen videos of a Nissan Patrol w/ 6.5 Supercharged.... and it EATS a Nissan Patrol with a 6.5 TD !!
Supercharge Your 6.5 Diesel
Old Mar 16, 2011 | 05:35 PM
Woody35's Avatar
bigger turbo, some custom tuning, bigger injectors. not many people have done it. call bill heath like it said above. he has a 6.5 with about 450 crank horsepower so he knows what to do.
Old Mar 16, 2011 | 07:38 PM
angelic0-'s Avatar
i emailed him, not sure if he opens his mailbox that often... i'm over in Iceland... there is really no chance i'm calling with the rates being that high
Old Mar 16, 2011 | 07:47 PM
Woody35's Avatar
if you want 300 at the crank your going to have to spend a little money to the keep the old 6.5 together. its not as strong as a cummins
