Need to figure out mileage drop
Old Mar 14, 2011 | 09:23 PM
BramanteCummins's Avatar
Default Need to figure out mileage drop
Ok, so I have a stock tranny and my milage has dropped to 14 at best. I can easily peg my tach at 2200 RPM and it takes that to get up to speed. I'm almost sureits the torque converter but my father keeps throwing everything else out. He says it's the TPS a bad alignment and this and that. The TPS hasn't changed since it dropped (mileage), the alignment is fine. Any other ideas or am I right and it is the converter.
Forgot about the signature
Last edited by BramanteCummins; Mar 14, 2011 at 09:23 PM. Reason: Automerged Doublepost
Old Mar 14, 2011 | 09:37 PM
madmikeismad's Avatar
TPS won't cause that. And I don't even know how you can get alignment issues out of power loss.
With a slid plate your TC probably did die after time. And that would definitely cause some sluggishness. If the motor runs fine and revs fine with no smoke or sputtering or anything, I'd put money on TC or clutches. Might be time for an overhaul.
Old Mar 14, 2011 | 10:32 PM
Is not that the power went away but my mileage. Went from 20 to 13, I basically need someone else besides me to explain why it's the torque converter cause I can't do any major work without my father agreeing.
Old Mar 15, 2011 | 02:23 AM
If the power is still there, but the mileage is gone....
are you driving it any harder than usual?
When did you notice the drop in mileage?
Are you still running #2, or is there any chance your pumps switched to #1 for the winter? (#1 rapes my mileage)
Have you recently switched filling stations? New one might have bad fuel?
Running any additives or anything?
Does overdrive work and torque converter still lockup? (if they still work, it's not your tps)
Any new parts? Truck still runs fine? Any smoke, and what color?
Old Mar 15, 2011 | 08:55 AM
Ive been driving it easier than normal cause of the expense
Its been gradually dropping
Not sure on how to figure out fuel differences
Ive been going to the same one
I run a splash of additives with every tank
It locks up and it can be slipped with relative ease
No new parts, truck runs smooth at all rpms except when cold but thats normal, and it smokes when i put my foot into it at lower rpms and its black, never white, sliiigghtt bluish when just started up.
Old Mar 15, 2011 | 02:19 PM
BRE's Avatar
BRE
Fuel Filter and air filter. Two easythings to check and see what happens.
Old Mar 15, 2011 | 03:48 PM
Considering I got the new filter mid summer I'll bet on the fuel filter. Copletely forgot about it!
Old Mar 16, 2011 | 11:12 PM
stackboy6.9's Avatar
yep its your fuel filter.my friends cummins went from 18 to 12 cus of his filter
Old Mar 17, 2011 | 12:02 AM
I'll change it out this weekend hopefully and in a week I'll hopefully have my old mileage back! Thanks
Does anyone happen to know what the stall speed of the stock TC is?
Last edited by BramanteCummins; Mar 17, 2011 at 12:02 AM. Reason: Automerged Doublepost
Walker.B
Chevy/GMC Duramax 01-04 LB7
11
Jun 17, 2015 10:40 PM
Powerstrokin7.3
Jun 13, 2015 08:47 PM
Nov 12, 2014 08:10 AM
Offshore725
Potential Diesel Owners Forum
Nov 11, 2014 08:03 PM
Dirty Offio
Big Rigs & Semis
Nov 4, 2014 07:43 PM
