Turbo or wastegate issure
Old Mar 13, 2011 | 06:10 PM
ProMow's Avatar
Default Turbo or wastegate issure
My 05 ctd hasn't been doing so well. I have noticed that i do not hear the turbo "bark" or the release of the pressure when you let out of the throttle. For example stall it out like doing a burnout and let off you here the "bark" or "surge". I do that and no noise at all. I am smoking more that normal also (stock truck).All thats done to it is straight pipe and silencer ring mia. Should I have a noise? Is the wastegate stuck open? Any ideas?
Old Mar 13, 2011 | 06:21 PM
prison's Avatar
if its a rubber line clamp it and see if it changes
Old Mar 13, 2011 | 08:33 PM
cerberus60's Avatar
If you have been doing much of that then you might very well have a turbo problem. They don't like a lot of that.
What is you boost doing under normal, loaded, and gettin' after it conditions? Thats your best gauge of turbo health.
Old Mar 13, 2011 | 09:05 PM
Klickster102's Avatar
my waste gate seems to not be working as well under lower rpms. u will lightly hit the gas pedal an then let off and it kinda makes the truck surge, idk if thts normal or not. it also seems to blow a little more smoke and its all stock. so my problem is similar to yours, anybody know?
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
