02 Auto Trans
Old Mar 13, 2011 | 03:15 PM
Laster's Avatar
Default 02 Auto Trans
I recently bought a 02 Dodge 2500 4wd auto, bone stock w/ 58,000 miles. I was driving it today and it won't stay in overdrive. About 55-60 mph or 1500-1700 rpm seems to be the worst about kicking in an out. I was on flat roads maintaining a steady speed. I'm new to auto transmissions behind a Cummins but this don't seem right.
Help or suggestions appreciated.
Old Mar 13, 2011 | 05:13 PM
Sounds like your Torque Converter is locking and unlocking. Its caused by an electrical noise. Only real fix I found was to install a DTT Noise Filter.
DTT Performance Diesel Transmission and Power Accessories
Old Mar 13, 2011 | 05:54 PM
Laster's Avatar
Thanks for the info, are these much trouble to install?
Old Mar 13, 2011 | 07:56 PM
turbo20psi's Avatar
No it is not hard to install.. There a pic in my profile with it installed ..check your grounds on the battery and also from the battery to the block,ECM,Everywere there is a ground for cleaniness and that there tight.
Old Mar 13, 2011 | 08:24 PM
RAW's Avatar
RAW
You could also try this.
http://www.suncoastconverters.com/im...d%20rewire.pdf
I tried this, but a little different. I didn't cut and extend both wires, I just put one wire in from a cab ground to the ground wire of the APPS, t-ing it in.
Old Mar 14, 2011 | 12:20 AM
Ramrob02's Avatar
hello, I have posted a fixed that helped. I have a 02 cummins automatic, Several people on here have good results with and it, wont cost you anything but your time. There is a neutral ground wire that run fromthe alternator area to the battery on the passenger side by the aircleaner. its a large black with a white stripe on it. follow this wire back to the alternator, it will run into a large wire loom under the valve cover. remove this large black and white striped wire from this loom it will end with 3 or 4 smaller 16ga black w/white striped wires at the end. Now zip tie this wire to the top raditor hose away from the large wire loom. Reason being this large black white striped wire is neg. the wires in the large loom are pos. This fix total cured my problem with lock-up, I also am ruuning a BD noise diode. but this is what totally cured my problem!
Old Mar 14, 2011 | 12:40 PM
Laster's Avatar
Thanks guys for all of your help. I will definately look into these suggestions!
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
