tranny up 06 cummins auto second not grabbing
Old Mar 13, 2011 | 01:54 PM
needmoreplaymoney's Avatar
Default tranny up 06 cummins auto second not grabbing
Any recommendations on where to.look first it would always slip out of second.for the longest time which I could work around.but now it wont barley grab second takes a few seconds almost like a couch slipping.on a stickshift
Old Mar 13, 2011 | 02:16 PM
NadirPoint's Avatar
What's the fluid look like?
Old Mar 13, 2011 | 02:24 PM
Little dark seems like almost somethin been burnin black stuk on dipstick didnt wanna get tranny flush quite yetincase it was a well know problem with quik fix. The fluid it above the mark by a little when I test it and feels good to the touch it doesnt feel wasted
Old Mar 13, 2011 | 02:32 PM
NadirPoint's Avatar
I would drop the pan, have a look see what falls out or laying in the bottom of the pan. Loosen the valve body to drain the converter as well and re-fill with ATF+4 and a new filter.
Go from there.
Old Mar 13, 2011 | 02:35 PM
Sounds like a start I let you know the outcome thanks
Old Mar 13, 2011 | 08:42 PM
cerberus60's Avatar
Not sure what " like a couch slipping.on a stickshift" really means but it sounds painful.
From your description, the front band is way out of adjustment and probably burned up along with some clutch packs. Check your front band setting and dump the fluid to see what happens. You may be able to get a few more miles if you drive easy.
Loosening the VB is a waste of time. Remove the rear cooler line and slip a hose over it that is routed into a bucket. After you drop the pan and change the filter refill the trans with 6 quarts of fluid.
Start the engine in neutral and watch the flow out the return cooler line. Whne it starts slowing shut the engine off and refill with another 6 quarts and repeat. Usually twice will get you clean looking fluid coming thru the cooler and you shut the engine off, connect th eline and fill to full.
Thats will flush 90% or better of the old fluid out of the trans and clear the cooler lines of possible build up.
Old Mar 13, 2011 | 08:58 PM
Couch=clutch haha touch phone my fat fingers I'm gonna go ahead and get the flush and filter change at my.buddys shop.......unfortunately I dont know about diesels ill build you a satellite structure from scratch but I can do on my truck I leave that to my buddy shop that's for all the info tho ill pass it on for sure
85IDI_International
Apr 24, 2015 01:08 AM
metrickjb
Jan 21, 2015 04:16 AM
TNTPrime
Jan 5, 2015 06:13 PM
Montz
Nov 12, 2014 05:10 AM
Tower crane guy
Oct 22, 2014 06:04 PM
