P pump swap question
Old Mar 12, 2011 | 11:40 PM
Chevy72's Avatar
Default P pump swap question
Hey there. I'm planning a P pump swap on my 91.5 i/c motor. I know I need the inner and outer gear covers, the p pump, and the fuel lines. (also wiring, fuel in and return and that little stuff too) Do I need to use the cam and/or cam gear from the p pump motor or will my cam and gear work?? Is there anything else I need?? I want to have everything ready before I tear down. any help would be great. Thanks!
Old Mar 13, 2011 | 07:35 PM
kieron_kohlmann's Avatar
https://www.dieselbombers.com/5-9l-r...-complete.html
Old Mar 13, 2011 | 11:13 PM
Chevy72's Avatar
Hey thanks for the overview!! Very detailed pics. you mentioned you broke 2 lift pumps, you think this was from using the 1st gen cam or just got unlucky with the parts??? I don't mind spending the extra cash on an airdog, i'm just curious. thanks again
Old Mar 14, 2011 | 01:20 PM
I cant say for sure it was bad pumps. I dont know how i could have broken 2 of them though. The airdog is nice, especially when it come to priming, but whats more reliable? The airdog or a mechanical pump? Id stick with a mechanical one if you can. Maybe there is a difference in the cams? im not sure.
Old Mar 15, 2011 | 12:24 AM
Chevy72's Avatar
Yea it would be odd to have 2 bad pumps, but i've seen stuff like that happen before. I'd prefer to keep the pump mechanical, but I guess i'll do what I have to!!! thanks for your help and the quick replies. the sooner I figure all this out the sooner I can do my swap!!
Does anyone know if the 2nd gen cams will fit in the 1st gen blocks?? I looked at some aftermarkets and re-grids to see if they were different and they are listed as different part numbers. I'm wondering if the only difference is the drive for the lift pump??
Old Mar 15, 2011 | 05:55 AM
cummins_guy's Avatar
12 valve cams are used in all 12 valve 5.9l Cummins engines, you can even use the 12 valve camshaft in a 24 valve 5.9l Cummins engine.
PA 24valve
Aug 31, 2015 06:08 AM
ItsAChummins
May 15, 2015 05:02 PM
moneypitk5
Feb 12, 2015 11:01 AM
CJJD4640
9
Feb 9, 2015 07:22 AM
Duncan
Oct 28, 2014 12:34 PM
