Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
COMPONENT QUESTION?
Old Mar 12, 2011 | 06:52 PM
cbsmoraine's Avatar
Question COMPONENT QUESTION?
Ok so i have what i think is a trans fluid leak on the driver side wheel well. i know the brake fluid resivor sits on top of the component leaking, and i know i probably need a gasket or seal to fix it. only prob i have run into is i do know what the component is called so i can order a seal/gasket to fix it. like i said i know my brake fluid res sits right on top of it, its a long almost cylinder shaped part with 4 or 5 lines coming off of it and runing every which way. i want to say its trans fluid coming from it, cause the fluid is red and smells like trans fluid, but heck i dont know what kind of brake fluid was put in it last so it could very well be that. anyone know what this part is called and if it is common for it to leak? its leaking from the center of the part. where it looks like it is bolted together, so its a 2 piece part.
Old Mar 12, 2011 | 08:10 PM
TruePerformanceDiesel's Avatar
FormerVendor
I think your talking about power steering fluid. It goes from the power steering pump to the brake booster on the brake master cylinder. That seems to be a common problem.
Old Mar 13, 2011 | 03:58 AM
cbsmoraine's Avatar
That could be it. i am going to get a pic of it and post it tomorrow
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
