loses power
Old Mar 12, 2011 | 12:45 PM
kiddiesel35's Avatar
Default loses power
Im working on a 2005 dodge 2500 cummins for a friend of mine. The truck is losing power after it warms up to around 120 degrees but it runs fine when is cold. Also when you press the brake and stop the truck it almost dies out like its being choked out. We have changed the thermostat, injector pump, lift pump, checked all the ground wires and electrical plugs, fuel filters and all. But it hasnt changed anything it has been to 2 diffrent shops that specialize in this type vehicle and they could never find anything wrong. the dodge dealership did everything they possibly knew to do but none of which did any good. It has a automatic trans and i am wondering if it could be something to do with it making the truck lose power and nearly die when you stop it. I have almost drivin my self crazy with this truck and I have no idea what could be wrong. Is there anyone that could maybe give me some tips or help?
Old Mar 12, 2011 | 06:38 PM
dangerous1965's Avatar
Torque converter failure? How does the tranny fluid look? What are the rpm's doing? Did you try putting it in nuetral and see what happens? Do you have a rail guage?
Old Mar 12, 2011 | 07:16 PM
I was thinking it could be the torque converter but im not sure. I checked the fluids and they were fine. The rpms will pick back up when you put the truck in nuetral but as soon as you go back to drive they fall agian. when your goin down the road after it warms up the rpm will barely pick up when you give it fuel. But it has no power after it gets warm. The dodge dealership and culumbus diesel both had the truck in there shop and both put gauges on it. They put a injector pump and lift pump but it didnt help anything there were no change in the truck.
Old Apr 1, 2011 | 07:05 PM
chiggerridge's Avatar
Default Same trouble
Im experiencing the same problem with my 2005. It is my only vehicle, so it is urgent I figure this out. I have installed new injectors, and my snap on computer indicates fuel pressures are good. I installed a new FCA and it made the truck run like new until engine reaches operating temp. Lots of black smoke and no power. Trouble codes keep saying low voltage problems, but when checked voltage is correct. Have you solved your problem yet? Any information would be greatly appreciated.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
