EJWA Install
Old Mar 12, 2011 | 02:04 PM
KillStroker's Avatar
Default EJWA Install
So I installed my EJWA last night I installed the BD stealth plate with no test light. But It was sucessful. But as I assumed its only getting 9psi at the injection pump. Good thing I got the AD 150 to install next. My question for you guys is since my HY35 is hard lined, how do i get my boost psi?
time for a turbo upgrade
Last edited by KillStroker; Mar 12, 2011 at 02:04 PM. Reason: Automerged Doublepost
Old Mar 12, 2011 | 02:22 PM
Red_Rattler's Avatar
High Tech Redneck
from the map sensor, part of your harness that should be plugged in
Old Mar 12, 2011 | 03:02 PM
Thanks Red Rattler, I figured it out my 05 was a manual and it registers when your just sitting there. My 02 is an auto so i had it in park. so when i revved it up it didnt register. Im a retard took all but 3 ft in drive to figure out my IQ.
I need to get that AirDog Installed the Pump PSI are not good.
Last edited by KillStroker; Mar 12, 2011 at 03:02 PM. Reason: Automerged Doublepost
Old Mar 12, 2011 | 03:13 PM
High Tech Redneck
Keep the chip OFF till you get one. Your on borrowed time as it is...
Old Mar 12, 2011 | 04:03 PM
keep it on stock till i install it then
Old Mar 14, 2011 | 06:48 PM
chad83181's Avatar
Yes A failing pump will not support the EJWA, your VP 44 will be pulling the slack of the failing lift pump, in turn getting hot itself by not getting enough return fuel to keep it cool, which killis the solder contacts on top of the VP 44. Thats Just from past experience with my Smarty, my failing lift pump before I put in a new one, would suck the fuel canister dry cause of the failing lift.
Old Mar 14, 2011 | 07:39 PM
RAW's Avatar
RAW
It is possible to plug the wastegate on a HY35, I have done it myself. I removed the actuator completely from the turbo, and threaded a machine screw into the tube of the actuator. I then ground down the head of the machine screw to match the OD of the actuator tube. Put it all back together, and made 31 PSI with it. Held together just fine, and still is on another truck.
Old Mar 15, 2011 | 01:38 PM
Did you have any over boost codes
JoeyMiR
9
Feb 3, 2018 10:05 PM
450r racer
8
Dec 21, 2015 06:42 PM
Gman30
Dec 27, 2014 12:46 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
