Alternator Guage?
Old Mar 11, 2011 | 01:39 PM
sweetv8s10's Avatar
Default Alternator Guage?
My alternator guage started flickering back and forth today if I turn the headlights off and on a few times it stops and sometimes it dissent stop but it still charges right around 14 but the flickering is really anoying and if I hold it at higher rpm it stops flickering also any ideas would be nice thanks.
Old Mar 11, 2011 | 01:51 PM
901stgen's Avatar
Its a typical first gen gauge man. My coolant temp gauge does the same thing.
Old Mar 11, 2011 | 04:47 PM
sweetv8s10's Avatar
I would almost agree with but it just started doing it and it was making my dome light flicker also so im not sure its just the guage.
Old Mar 11, 2011 | 04:54 PM
Farmboy 2.0's Avatar
I wonder if the alternator could be going T.U.. Have you checked to see if all the wires are free of corrosion? and tight?
Old Mar 12, 2011 | 09:49 PM
sweetv8s10's Avatar
I have checked everything I can think of im kind of lost now
If anyone has any more info please help I changed the alternator and its still doing the same thing.
Last edited by sweetv8s10; Mar 12, 2011 at 09:49 PM. Reason: Automerged Doublepost
Old Mar 12, 2011 | 10:09 PM
big bad diesel 416's Avatar
Site Sponsor
bad ground i fought that for about 3 weeks once then the whole dam truck quit get a common bus and start running ground wires to stock locations and non stock locations such as.....
Behind #6 valve cover
front clip by batt
lower dash support
gauge cluster
parking brake release (theres a screw there)
bed in 2 spots
under cab in 2 spots
any time someone has a electrical issue thats what we to and recommend works every time
do the one behind #6 that dose ALOT including head lights
Old Mar 13, 2011 | 12:50 AM
jdbigblue12v's Avatar
i had the same problem and it ended u being stater in my alternator and had a bad ground on the core support. try sanding down paint on ground areas, if this doesnt work yu may have melted a wire or PCM could be bad.
Old Mar 13, 2011 | 09:00 PM
sweetv8s10's Avatar
This may sound dumb but what is a common bus and where do I bolt the one on the back of the motor?Could someone take some pics of where they bolted all of there grounds?
Old Mar 13, 2011 | 09:06 PM
Site Sponsor
a common buss is this http://www.canadianmarineparts.com/w...es/FS40720.jpg
thats actually the exact one that I have and that I use
on the back of #6 its right behind there on the fire wall you have to look under all the factory insulation and what not its too cold for me to go out and take pics
these trucks only have like 2-4 grounds factory so put as many as you want anywhere you cant over ground
Old Mar 14, 2011 | 02:30 PM
sweetv8s10's Avatar
Would 10 guage wire be big enough or should I use bigger wire?
