Differences Between The 04.5-05 Edge And The 06 Edge.
Old Dec 5, 2007 | 08:36 AM
CHEMMINS's Avatar
Default Differences Between The 04.5-05 Edge And The 06 Edge.
What is the actual differences between the 2?
I have heard you can run the 04.5 in an 06 without problems, but then I have been told you can't by others.
Reason I ask is that I have a friend who just upgraded, and wants to know if he can use his old edge in his new truck.
Thanks.
Old Dec 5, 2007 | 09:02 AM
staarma's Avatar
The injector connectors are way different between the two. Also, the 06 trucks' ECU communicates differently off of a CAN BUS than the 04.5-05. A harness plugs into the OBD2 port under the steering wheel for the 06 but not on the earlier models. I would say the PCB's are different as well. I think he's out of luck for sure.
