QUIT RUNNING WONT START
Old Mar 9, 2011 | 03:22 PM
billyray15301's Avatar
Default QUIT RUNNING WONT START
I HAVE O4 6.0 4TH GEAR FLAT ON THE FLOOR QUIT RUNNING WON'T START OIL LEAKING AROUND DAMPER PULLY FRONT SEAL AREA NO OIL PRESSURE ON GAUGE
Old Mar 9, 2011 | 07:33 PM
Mdub707's Avatar
Tough to say without more info, but if oil is leaking, it definitely wont run, since the injectors are fired off of the oil... 2009 powerstroke huh? New one to me!
Old Mar 9, 2011 | 07:53 PM
prison's Avatar
09 6.0L? did you switch engines or do you really have a 6.4?
Old Mar 10, 2011 | 07:59 AM
Mdub707's Avatar
His post says 04 6.0, so I'm guessing that's what it is, I was just breaking his *****.
Old Mar 10, 2011 | 10:20 AM
break them later help me fix it first please
Old Mar 10, 2011 | 01:31 PM
Mdub707's Avatar
Can't really give you any more info about it until we get more info from you. How many miles on the truck, how is it used, when and how did it happen or when did you notice it? Any ideas at all where the oil is coming from? Kind of hard to diagnose from here....
Where are you located?
Old Mar 10, 2011 | 02:32 PM
bobfbigman's Avatar
sounds like you blew the oil pump up, it sits right behind the cover plate behind the damper, you said flat to the floor, what RPMs were you at, pump failure has been know to happen if over 4K rpm
Old Mar 10, 2011 | 03:16 PM
Mdub707's Avatar
6.0's aren't fast until after 4k rpms though!!!!
Old Mar 10, 2011 | 08:10 PM
mini max tuner close to 4200 rpms
Old Mar 10, 2011 | 09:34 PM
bobfbigman's Avatar
the stock pump gear is cast, I believe Elite Diesel sells a billet pump, look for holes behind the damper, when they explode it gan punch through the front case.
