Smoke
You could put a plastic bag over the air cleaner? (yes, this is a sarcastic response, but it will definitely result in smoke)
Why do you want smoke? Smoke is wasted fuel and excess heat....both generally BAD things...
If you would like more smoke (or power), you can move the fuel plate forward or custom grind it. You can also tune your AFC with a softer spring and dial the star wheel to its least compressed position (turn toward engine moving AFC spring pearch forward thus relieving any preload on the AFC spring), and turn the "smoke screw" all the way in which bumps up the initial max fuel position with zero boost. After that, you're looking at bigger delivery valves and bigger injectors... Just please keep in mind the added heat that smoke brings with it. Get some gauges to monitor EGT and boost, then start tuning for desired output without melting down the motor. Words of experience...trust me.
get some 370 fuel injectors,pinch the wastegate,tune the AFC,staright pipe your exhaust,& to let ya know soot is unburn fuel so your wasting your diesel causing extra heat im all for rollin coal but its not always the best thing to build your truck for
smoke is NOT power, contrary to popular beleif... wasted $$$$$ is all... people with high EGT, horrible fuel milage and a black trail of money following them are truly ruining motorsports in general. if you want it to really smoke ^what prison said
thanks rattle bomb. i'm glad theres still some out there that follow my belief
Originally Posted by wt_offroad
EH..... Cheap and easy way.... you can even get it at wall mart. Go back to the women"s section. Ask the clerk for a pair of extra large Granny panties. now go out to your truck and open the hood. put the panties on your head. take the bag they gave you and wrap it around the air filter jump in it and go. You will look just as dumb as the cloud coming out of the pipe.....
