engine fan
Old Mar 8, 2011 | 06:30 PM
steiger855's Avatar
Default engine fan
i have a 05 and have to change the fan and fan clutch. just wondering if anyone has changed one? and the best way to get the fan out?
Thanks Sam
Old Mar 9, 2011 | 12:00 AM
cummins army's Avatar
cut your fan shroud in half and then remove it is what i did then you have plenty of room to work in there and when you put it back in i drilled some holes in my fan shroud and used zip ties and stitched it back together so it wouldnt move that was something i learned from friends in high school that drove imports when they would brake there body kits but thats what i did hope it helps you out
Old Mar 9, 2011 | 12:11 AM
Drew Slayback's Avatar
There is really no easy way to change it. if you want to cut your fan shroud you can but most people dont want to cut it, def. not a nice truck! just take your time and take the ac condenser,radiator, etc.) off and you can get in there no problem. but watch unpluging the connecter they break easy.
Old Mar 10, 2011 | 11:22 AM
steiger855's Avatar
Well got it fixed, the fan clutch nut turns to the left when standing infront of the truck. ended up being able to drop the fan out the bottom and unbolted and pulled the shroud out of the top. all in all went alot better then i thought! first time ever with this thing!!! And once you get it loose you can spin it with a 1 1/5 wrench if you dont have a 36mm and i took a flat strap of 1/8 inch drilled a hole in it to slip over the pulley bolt to hold it from spinning on me. used an air hammer to get it to break loose. had to hammer the **** out of it to get it to break loose.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
